1:70 Hannah
Ship Model Okumoto
Catalogue #
Available from Ship Model Okumoto for ¥ 33,000 (approx. $290)
The schooner Hannah was the first armed American naval vessel of the American Revolution and is claimed to be the founding vessel of the United States Navy. She was a fishing schooner owned by John Glover of Marblehead, Massachusetts and was named for his daughter, Hannah Glover. The crew was drawn largely from the town of Marblehead, with much of the ships ammunition being stored in Glover's warehouse now located at Glover's Square in Marblehead before being relocated to Beverly, Massachusetts. The schooner was hired into the service of the American Continental Army by General George Washington. Washington commissioned Nicholson Broughton to command the Hannah on 2 September 1775 and ordered the vessel to, "...cruize against such vessels as may be found . . . bound inward and outward to and from Boston, in the service of the [British] army, and to take and seize all such vessels, laden with soldiers, arms, ammunition, or provisions . . . which you shall have good reason to suspect are in such service." Hannah set sail from the harbour of Beverly, Massachusetts on 5 September 1775, but fled to the protection of the harbour of Gloucester, Massachusetts two days later under the pursuit of HMS Livelyand a second British vessel. Leaving Gloucester Harbour, Hannah captured HMS Unity.
Hannah's brief naval career ended on 10 October 1775, when she was run aground under the guns of a small American fort near Beverly by the British sloop Nautilus. After a 4-hour engagement between the British ship and Beverly and Salem militias on the shore, Hannah was saved from destruction and capture. According to legend, soon after Hannah's decommissioning, the schooner was towed to Lee's Wharf in Manchester, where its name was changed to Lynch. There, the vessel was restored to working condition by 7 carpenters over the course of 3 weeks. In March of 1777, Lynch was sent to France with congressional correspondence for Benjamin Franklin, who was there as U.S. Ambassador. Upon embarking on their journey back to the U.S., Lynch and its crew were captured by British ship HMS Foudroyant. Lynch was sold as a prize by the British and documentation indicates that the schooner was used as a merchant vessel thereafter.
Edit courtesy of Wikipedia
The kit
Hannah is the fourth release from Ship Model Okumoto and has only been on sale for a week or two, so my thanks to those guys for getting this out to me from Japan so quickly. According to their website, this is the kit specification:
  • Scale:                                     1/70
  • Total length:                            335mm
  • Height:                                    90mm
  • Width:                                     100mm
  • Wood:                                     Agathis
  • Build time:                              100 hours
  • Parts count:                             310 laser-cut parts, dowel
As with my previous reviews for La Couronne, Endeavour and Santa Maria, this kit is packaged into a transparent, lockable box. However, this one is smaller, and our postie actually managed to pop it through our letterbox! As well as being smaller in general size, it’s about half of the depth of the previous releases and has some separate green plastic locking clips to hold it together. Inside, we have eight sheets of laser-cut Agathis wood, a small bundle of dowel, plans, instructions and a parts list.
A hallmark of Okumoto’s kits is the very low scorch that results from cutting via laser. You can see that very little heat has crept into the area adjacent to the cut, and there is no discolouration of the parts. A simple clean-up of the edges is all that’s needed, so remember to do this to each inner frame edge and component before assembly. All parts are also nigh-on cut through in their entirety, so lengths of tape have been attached to the rear of the sheets, holding each part securely in place. Removal of the parts shows that no sticky residues are left behind either. As with the other kits, there is no part nomenclature on the sheets, and you need to refer to the paper plan sheets to identify each component. There is a little laser etching on each sheet which indicates the sheet number, for reference, and also the sheet thickness.
Timber quality is excellent, with the Agathis being very fine grained. This should be nice and easy to work with, and you shouldn’t get any splitting etc. The slightly golden colour is also very attractive. Note that whilst these kits are POF, there are some simplifications in their construction. For example, these models don’t have cant frames. However, each frame is constructed from a number of individual components that would be similar to the way the actual ship frames were constructed.
A small bundle of short dowel lengths concludes the timber items in this kit.
Underneath the colour image of the completed Hannah, lies a profile plan that’s roughly A3 in size. This contains a port elevation as well as a partial upper and lower plan. Annotation is in English.
We next have three sheets that contain the parts maps for the eight sheets of timber supplied. These are exact duplicates of the timber planks with regard to layout.
Now, unlike the previous Okumoto releases, this one has a far more comprehensive instruction manual, again making this an ideal introduction to POF. Twelve sheets of paper are printed double-sided and stapled, creating a 24-page manual. Whilst this is still in Japanese, the photos are very good at explaining the steps. You can also use a smartphone app, such as Google Translate, so scan the text and convert it in real time.
Lastly, a series of sheets are included which show the frame and detail assemblies. For the frames, you simply put these together over the top of the printed paper, after applying a little wax, maybe, to prevent the timber from sticking to your plans.
Conclusion
Out of all the Okumoto kits now on sale, Hannah has to take the place of Santa Maria as the first one that a newcomer to POF should tackle. Whilst Santa Maria is a beautiful and relatively uncomplicated in comparison to La Couronne and Endeavour, I feel that Hannah is well-pitched in complexity and price, to possible be the first POF from Okumoto that you consider due to its straightforward design. It’s worth noting that despite being an easier build subject, it still has almost twice the number of parts, according to their website, than Santa Maria.  It’s also a little gem with its length of just over one imperial foot (13 inch, 335mm). A superb project that will look perfect on the mantlepiece and one that also won’t break the bank. Estimated building time is around 100hrs too.
Please let Ship Model Okumoto know that you saw this review on Model Ship World.
My sincere thanks to Ship Model Okumoto for sending this sample out for review on Model Ship World. To purchase directly, click the link at the top of the article.
Ongoing:
Hi James. Thanks for posting these reviews.
These look like very nice kits, and it was very nice of them to send you kits to review for free.
But, I'm a bit surprised to see your comment that none of the kits have cant frames, when I clearly see cant frames in the plan top-view and in some of the model images. Am I mis-reading something?
Clare
  • 2 months later...
Very nice review James.
Thanks
Phoenix, AZ
Current builds;
Previous builds, in rough order of execution;
Shipjack, Peterbrough Canoe, Flying Fish, Half Moon, Britannia racing sloop, Whale boat, Bluenose, Picket boat, Viking longboat, Atlantic, Fair American, Mary Taylor, half hull Enterprise, Hacchoro, HMS Fly, Khufu Solar Boat.
On the shelf; Royal Barge, Jefferson Davis.
4 hours ago, CharlieZardoz said:
Hi! Do you know if they sell the plans alacarte?
I wouldn't think so. Just the kits.
Thanks
A pleasure!
Ongoing:
Hmm that's a bummer if they don't. I did message them though. I'm wanting to make a plank on frame of Hannah at 1/64. Alot of the newer companies do offer plans to buy I've been slowly collecting them and converting the scales so those templates on this model would be just what I need. :)
Build on hold: HM Sultana 1/64th scale
Current Build: 31 ton Doughty revenue cutter as USRC Active 1/64th scale (in progress)
Future Interests: Ballahoo, Diligence, Halifax and beyond...
  • 4 years later...
Guess I am a bit late to post here, but just wanted to mention I have visited their site several times over the years (including today), and they always say the kit is "sold out"?
I get the feeling it's a mom and pop operation, except there's no mom, so the production run for each kit is pretty small -- probably most go to Japanese customers, since he doesn't perceive a need to cater to English-speaking customers.
